Author Topic: 3vz lost power  (Read 1590 times)
kauai_fab
  • Male Posts: 45
  • Member since Aug '08
3vz lost power
« on: Apr 22, 2009, 10:35:46 AM »
U got a 90 toy ex cab and its like it lost power on the low end. Its got 488 and use to float on sand without to much gas now its a plug motor what's wrongs?
  • Administrator
  • Turtle Points: 2205
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
Re: 3vz lost power
« Reply #1 on: Apr 22, 2009, 11:34:16 AM »
Does it have a smooth idle? Have you checked if all the plug wires are conducting?
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
  • Member since Jun '07
    • Buy me a drink
Re: 3vz lost power
« Reply #2 on: Apr 22, 2009, 11:49:28 AM »
sucked in any water?
got the cap/rotor wet?
filter wet?
fouled plugs?
plug wires all plugged in?
vac leak?
kauai_fab [OP]
  • Male Posts: 45
Re: 3vz lost power
« Reply #3 on: Apr 23, 2009, 01:58:09 PM »
Idles smooth.when shifting to second the engine bogs out when sand.on road you can tell it aunt a 3.0
Goose
  • Turtle Points: 52
  • Male Posts: 1,029
  • Member since Mar '07
  • >>Goose maN<<
Re: 3vz lost power
« Reply #4 on: Apr 23, 2009, 04:44:05 PM »
although its rare, its possible that your timing belt has jumped a tooth.
it will still run and idle fine, it just wont have any power whatsoever..
Id check for intake and vacuum leaks first though, and do a full tune up..
Baller Status: Coming Soon To A Toyota Near You!...   :afro:
My Life Is A Very Complicated Drinking Game... -Me
90 ext. cab v6, SAS'd, 37's
94 4runner -work in progress
www.slagfactory.com
My Buildups:
'90 ext. cab
http://board.marlincrawler.com/index.php?topic=38260.new#new
'94 4Runner
http://board.marlincrawler.com/index.php?topic=53882.new#new
Dingman.
  • Turtle Points: 1125
  • Male Posts: 3,448
  • Member since Oct '08
Re: 3vz lost power
« Reply #5 on: Apr 23, 2009, 06:18:00 PM »
CHeck your cat..  It maybe clogged.  you can unbolt the flange. and see if it helps.
Another thing you may want to chekc is the timing and compression of each cylinder.
Let us know what you find!
-Mike
Homefries
  • Male Posts: 241
  • Member since Apr '07
Re: 3vz lost power
« Reply #6 on: Apr 23, 2009, 07:42:19 PM »
I had this similar problem with mine a while back and it ended up being a couple of clogged injectors.  I checked by having the motor running and disconnected one spark plug wire at a time.  If the motor bogged down then the cylinder was firing.  If it didn't do anything then that is where the problem is.  Just be careful when doing this because you can shock the crap out of yourself.  Good luck.
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
Re: 3vz lost power
« Reply #7 on: Apr 23, 2009, 09:08:10 PM »
try checking the A/T Fluid.... you get shocked HELLA lol
  • Administrator
  • 511:1 Club
Re: 3vz lost power
« Reply #8 on: Apr 24, 2009, 08:28:45 AM »
If the engine fires up normal (starts easy) and has a perfectly smooth idle at 800-850 RPM, then I would say this is not a timing issue, not a timing belt issue, not a plugged injector issue, nor a burnt exhaust valves or any of the like.
I would immediately start checking every ground wire starting with the ground for the computer. Any solid brown or white-with-black-stripe wire you find ensure it has a good ground.
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
Re: 3vz lost power
« Reply #9 on: Apr 24, 2009, 11:20:47 AM »
X2 Very true.... something is getting a bad ground or grounding out.. (that kicks on at a higher rpm?)
kauai_fab [OP]
  • Male Posts: 45
Re: 3vz lost power
« Reply #10 on: May 01, 2009, 11:44:31 AM »
Can't be the
 Cat cause I took it out. But ill check the injectors. For now
Last post Jul 24, 2002, 03:08:12 AM
by trt2
Last post Feb 21, 2005, 11:20:04 PM
by Thumper
Last post May 22, 2006, 01:36:31 AM
by jimbo74
Last post Jun 12, 2006, 05:47:41 PM
by Bazzi
Last post Jun 08, 2006, 08:58:57 AM
by LILGREENYOTA
