Author Topic: Front disc brakes/brake grab during braking - 1977 Pickup 2wd  (Read 4167 times)
i_luv_my_truck
  • Turtle Points: -48
  • Male Posts: 157
  • Member since Mar '05
  • Toyota Crawler
    • My Rig
Hi!
Maybe someone can assist.  My 1977 hilux front disc brakes grab, as if something is getting skewed and grabbing during braking.  I did a visual inspection, noticed nothing out of the norm.
Any ideas?
Thanks in advance for any assistance,
Ernest
1977 Toyota Hilux 2wd - because because
1980 Toyota Hilux 4x4 - restoration project
1981 Toyota Trekker - nostalgia
1982 Toyota Hilux 4X4 LB - just because
1984 Toyota Hilux 4X4 - everyday driver
2001 Toyota MR2 Spyder - for speed
1993 Toyota Previa - for relaxing
http://www.cardomain.com/ride/2093325/
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
need more info, grab? do you mean pulling one way? or just going grab-grab-grab- as you make a stop. butt stops str8? if you use your E-brake (in a parking lot with on one around) and stop slower does it grab?
i_luv_my_truck [OP]
  • Male Posts: 157
  • Toyota Crawler
    • My Rig
i can't determine if it pull left or right during breaking, it seems to go straight.  it grabs and holds, until full stop. some times wheel/s screech.  i don't use the emergence break, seams totally loose.  i purchased the truck relatively recent.
thanks again.
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
The most common problem would be a rusted or frozen piston in your disk brake caliper.
Thur the years from heat and moisture in the brake fluid, debris builds up in the caliper bore and the piston is no longer able to move freely.
Time to replace or rebuild the calipers for starters.
Marlin
i_luv_my_truck [OP]
  • Male Posts: 157
  • Toyota Crawler
    • My Rig
Thanks for replies!  I'm going to check suggestions.
Last post Feb 16, 2005, 07:30:07 PM
by ntsqd
Last post Nov 29, 2006, 11:44:50 PM
by 46&2
Last post Apr 29, 2007, 10:51:58 PM
by Hammerhead
Last post Dec 23, 2007, 02:12:59 PM
by kneedownnate
Last post Feb 24, 2009, 11:18:28 PM
by NCK4L
