Well, it does not matter, the truck running correctly was a fluke, so the PCV is hooked up again. I played and tinkered all week trying to get it to idle and it was no use, only way I can get it to idle is to take the air cleaner off and choke it with my hand to make it have enough vacume to idle. Every gasket on the intake is new, the carburettor has been gone through, I even took someones advice and reset my valve clearances.So it is getting down to the point I am going to have to bring it to someone who knows better how to fix it.
if removing it makes it run better it was messed up,it makes things cleaner and even though we dont need cats and stuff, its the least we can do
Started by solidaxle16 General 4WD Discussion
Started by robrub00 Toyota Pickup/4Runner Tech 1979-95
Started by 1985ToyotaForLife Toyota Pickup/4Runner Tech 1979-95
Started by emsvitil Toyota Pickup/4Runner Tech 1979-95
Started by Grimmjow « 1 2 » Engine
