Author Topic: hard shifting on 88  (Read 1363 times)
jsrusse11
  • Member since Sep '04
hard shifting on 88
« on: Sep 08, 2004, 09:41:12 AM »
i have an 88 pickup with the 22re and five speed tranny. everything seems to shift fine except getting into first is rough, but after that everything is smooth. seem to get worse the hotter the tranny gets. already swaped fluid for lucas oil with the hardshifting additive from lucas also. is there any other way to help this out without rebuilding it. if thats what i might needs how hard is a rebuild?
derek
  • Turtle Points: -61
  • Male Posts: 600
  • slow truck=more time to nap
Re: hard shifting on 88
« Reply #1 on: Sep 08, 2004, 10:01:17 AM »
hows your clutch?
almost sounds like its not working correctly.
derek
Tool Guy
  • Turtle Points: -8
  • Male Posts: 33
  • Member since Jul '04
  • $800 84 Toyota
« Reply #2 on: Sep 08, 2004, 02:03:17 PM »
Check for air in the clutch lines first, then chek the slave cylinder maybe.
84 Toyota- Cost $800, BS 3" Rancho Lift, Worn out RS5000s, 32" A/T's, Burned up Radio, New Plugs, and Wires
86 Chevy- Cost $500, Dead Battery, Out of Registration, No Inspection, a few holes in the bed
03 F150- Cost I still cry about, K&N FIPK, Dumped Flowmaster, Pioneer Head Unit and AMP, 4 ways and 10" Sub
03 F150- Company Truck, Stupid useless tonneau cover, stupid sticker telling everyone who I work for, wasted space in my driveway
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
« Reply #3 on: Sep 08, 2004, 09:41:28 PM »
To begin with, first replace the green shifter seat and the nylon socket on the end of the shifter handle.
With the engine idling and the clutch pedal pushed to the floor, and after you wait for the gears to slow down. Shift into reverse. If you can shift into and out of reverse without any constant grinding, the problem is not in the clutch. You could have a worn 1/2 fork, failed syncrow, or the constant mesh teeth, [on the side of the 1th speed gear and the mating teeth on the 1/2 hub], could also be worn out or laid over.
This is a common problem in a high mileage trans that has been constantly down shifted.
DO NOT DOWN SHIFT. It wears out the syncrows, gears, and bearings on the coast side.
Marlin
jsrusse11 [OP]
« Reply #4 on: Sep 08, 2004, 11:59:00 PM »
i already checked the green rubber seat and looks good but i might change it out anyway.  i can shift in to reverse no problem when idleing.  it's only first that has the problem.  does this mean a rebuild is the only answer or should i get into the bell housing and check first.  i can do that myself but i don't know anything about trannies.  how much would it be to get rebuilt if i need it?
Last post Dec 02, 2005, 08:43:04 PM
by rockscrambler
Last post Jun 12, 2008, 07:39:06 PM
by brainlessfool
Last post Feb 05, 2024, 08:40:49 PM
by Shamb
Last post Oct 13, 2010, 06:21:15 PM
by BIG-T
Last post Apr 19, 2011, 07:25:10 AM
by weakyota91
