sorry to be such a newb and bug you guys all the time with my stupid questions but......
part of the reason i go this cruiser for such a good deal is it makes a noise. 1st off its a chevy 350 mated to a 76 landcruiser 4 spd. mated to a 67 tcase from a 3spd setup.. some history: it had the stock 3 spd and didnt make the noise till the previous owner swapped in the 4 spd.. and something that might be worth mentioning they welded a plate to the side of it for the slave cylinder since the rig didnt have a hydrolic tranny before.. now my problem: when you push the clutch in, doesnt matter how little or far it makes a noise that sounds like a bearing going out real bad. after you drive it for a little while it stops for the most part. but other then the noise it seems to work just fine. i lose clutch pressure sometimes but i think the master is going out so probably not related.
the first thing we tried was the throwout bearing cause thats the most obvious solution and when we pulled it out it was pretty beat up. nope. the new one didnt fix it.
so then a tranny guy i know said its probably the bearing the main shaft rides on in the tranny. when you push in the clutch it takes the load off of it and allows it to move. pulled it out and sure enough it was impossible to turn the shaft by hand. so i figured thats got to be it. i got a good deal on a new tranny that looked great and the adapter to run the 3 speed tcase since i got one with the lc and put them in. just started it up a few minutes ago and still makes the dang noise. what else could it be?? someone said something about adjusting the clutch or something like that and i dont see anything that can be adjusted. im fairly mechanicly inclined i just dont have much expierence with these older setups so any advice would be great. thanks in advance for any help guys... ps: sorry about the long read.
