Author Topic: hydro assist question  (Read 1412 times)
Steve_925
  • Turtle Points: -86
  • Male Posts: 1,876
  • Member since Feb '07
  • F***in catalina wine mixer
« on: Feb 18, 2008, 10:33:41 PM »
just ordered my hydro assist. i'veread up alot on it. rite now im kinda planning it out, my question is i have some angle iron that would work perfect welded to the front of the tie rod to help it from bending. i have heard alot of people bend there tie rods, i know sometimes its because of ram pushing farther than the steering can accually go. is there any reason not to weld the angle iron on it? toy axle hi steer 37s. thanx
UA 342
STEAMFITTERS
Hammerhead
  • Turtle Points: 100
  • Male Posts: 564
  • Member since Nov '04
  • Junkyard Dog
Re: hydro assist question
« Reply #1 on: Feb 18, 2008, 11:09:45 PM »
Angle iron looks way redneck and has squat for strength.  Get a piece of tubing or pipe that will fit over the tie-rod and slide it on with one TRE removed.  Reassemble and buzz it on at both ends.  A sleeved tie-rod is much stronger and looks fine.  If your ram tries to push the steering past the stops you can shim the ram to limit the stroke.
'82 pickup, +3, locked, doubled
'82 pickup, IFS long travel, V8
'85 4runner, V8 rock crawler
'88 X-cab, V6
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #2 on: Feb 19, 2008, 05:46:30 AM »
what size is your tie-rod? x2 on sleeving the tube if necessary....(instead of the angle)
Quote
almighty_yota
  • Member since Oct '07
« Reply #3 on: Feb 19, 2008, 09:53:41 AM »
I think you should wait to see if you even need to strengthen the tie rod.  Whats the material right now?
Closer you can get the stroke of the ram to the tie rod, and being parallel with the tie rod; the less bending force you'll create on the tie-rod as well.  Keep that in mind when you are mounting the ram.
edited for a typo.
Steve_925 [OP]
  • Male Posts: 1,876
« Reply #4 on: Feb 19, 2008, 12:48:24 PM »
its 1.25" i believe. its from all pro. how much of it shoul i sleeve
UA 342
STEAMFITTERS
Last post Mar 05, 2006, 04:37:42 AM
by POWERSTROKEN
Last post Jul 24, 2010, 10:14:40 AM
by megolfer
Last post Sep 15, 2007, 09:25:38 AM
by subliminaltrips
Last post Nov 11, 2007, 09:00:16 PM
by Volcom
Last post Feb 26, 2008, 07:56:05 PM
by incontrol
