Toyota made a 1 ton dually version of your truck but I don't' know where you could find rear springs for one. It was a spring under 2wd but you could put them on top of the axle
I was only talking about using the springs, not the whole axle.
I'd go with the Downey's or Rancho's and crank them in until you sit level again. That should help keep the frontend up, of course when the blade is down you'll sit high in the front. Then when you take it off for the summer you can uncrank them for use without the plowEdit: Actually you may be ok in the summer since you won't have all that salt/sand in the bed either.
Started by Jimmyg Project Research and Build-Ups
Started by MOOSEKNUCKLE Engine
Started by 84runner General 4WD Discussion
Started by Plekto Engine
Started by Rocksurfer Chit Chat Camp
