i have a complete 91-92 efi set up off of a 22re with intake(with smog) /harness/ computer make reasonable offer at (grumpy1@netptc.net)
p.s. i dont have the knock sensor i can get them for about 75.00 with a kit to install on pre-85 block (pre 85 block does not have a mounting for the k.s. and it sould be up high on the block to function properly and not be mounted to any part of the motor that has other items bolted to it as false knock sensor signals can result and the signal from the k.s. tells the computer to retard the timing which results in poor engine performance
