Some key stock still needs to be welded to the forward shift rail to keep the shifter engaged.The rails would be switched if your getting leftovers from a friend who went duals.
I'm guessing to get 2-lo with one stick, this is where you would grind another groove.
actually, with 2-lo, you remove the part of the shift rod that keeps you from crossing back over to 2wd when you're in neutral or low range(the slots misalign so you can't move the shifter over).
Can anyone tell me why Marlin's twin stick can be used with 84-88 forward shift T-cases but not with forward shift cases from 89-95? What's the difference?
Would the twin stick wowrk with a W56 if I found a way to mount it? I mean , assuming it could be mounted somehow, would it still function properly? Sorry about this thread getting a little off topic...
Started by KToy Toyota Pickup/4Runner Tech 1979-95
Started by greg_k113 Engine
Started by runner88 Parts For Sale
Started by motormouth559 For Trade or Barter!
