Author Topic: 3rz A/C swap question  (Read 644 times)
angle1991
  • Male Posts: 4
  • Member since May '17
« on: Apr 04, 2022, 08:19:56 PM »
I've got a 95 4runner that was originally a 3.0 auto,. It's now got a 2002 4 coil 3RZ in it. What do I need to do to make the A/C compressor clutch engage? Everything is hooked up and charged but the clutch won't engage off the button on the dash.  Can't seem to find anything on a 95 reading through the swap thread.
Thanks!
Gnarly4X
  • Turtle Points: 5134
  • Male Posts: 4,254
  • Member since Jun '16
  • 4-wheeling vicariously.
    • Buy me some coffee
Re: 3rz A/C swap question
« Reply #1 on: Apr 05, 2022, 06:51:10 AM »
I don't know about your engine, but in my 22R and 22RE there is wire to the compressor that energizes the clutch.  The switch on the dash activates that wire.
Is a wire attached to the A/C compressor, and did you check that there is 12 volts at the wire?
Gnarls. :usa:
« Last Edit: Apr 05, 2022, 07:07:37 AM by Gnarly4X »
angle1991 [OP]
  • Male Posts: 4
« Reply #2 on: Apr 05, 2022, 07:35:04 AM »
Yes everything is connected and hooked up with not getting power at the clutch.
liveoak
  • Turtle Points: 102
  • Male Posts: 155
  • Member since Mar '08
« Reply #3 on: Apr 05, 2022, 11:50:46 AM »
did it ever work after the swap? did the person that did the swap connect the compressor clutch wire from the 3rz harness to the clutch output wire from the ac amplifier on the 4runner?
I have a lot of ac notes and wiring notes here https://forum.ih8mud.com/threads/3rz-2rz-swap-notes.1236525/
my guess is that you need to connect the light green wire from the 3rz IK2 plug to the black/white? 4runner body harness plug or whatever color the ac amp clutch wire is on the 4runner. most likely behind the passenger kick panel.
« Last Edit: Apr 05, 2022, 01:01:39 PM by liveoak »
Last post Feb 22, 2009, 07:59:57 PM
by shoope1
Last post May 05, 2010, 08:25:32 PM
by kauaikid
Last post Jun 10, 2010, 12:39:52 PM
by SFD4x4
Last post Aug 03, 2011, 10:33:45 AM
by tryn2Crawl
Last post Feb 06, 2016, 11:49:51 AM
by Chriseldredge
