I'm trying to install a solid spacer during a rear end rebuild. When I install the spacer without any shims, then torque the nut to as low as 80 inch/pounds, I am not able to turn the pinion gear. The solid spacer's length is 2.371" and the original crush sleeve is 2.38". Everything is new...the ring/pinion gear and all bearings.
It's a 1986 4runner with non-turbo 22re originally. Everything was ordered for toyota 8" with 4 cylinder, but here are part numbers in case that plays a role.
Trail Gear 140059-1-KIT solid spacer kit
Motive Gear MGR-T411 ring and pinion set.
Appreciate any replies
