Author Topic: 4.30 gears 34-36" tall tires and a 1.9 ALH  (Read 1096 times)
obrut
  • Turtle Points: 171
  • Male Posts: 18
  • Member since Dec '20
« on: Nov 29, 2021, 09:05:40 AM »
I have an 80 that I'm building.  I finished doing a W56B and dual case swap and have long term plans for a M-TDI ALH swap.  My truck has the factory 4.30 (4.37?) gears and I currently have 34" TSL, I might swap to 36" at some point and that would probably be the tallest.
Thinking long term, am I better off with the 4.30s for the diesel or does it still make sense to re-gear to 4.88 or 5.29s?
I'm concerned about the lower redline on the diesel and too much gearing especially with smaller tires like 34-36"
H8PVMNT
  • Turtle Points: 452
  • Male Posts: 3,554
  • Member since May '07
  • I'LL NEVER MAKE IT...
Re: 4.30 gears 34-36" tall tires and a 1.9 ALH
« Reply #1 on: Nov 29, 2021, 05:58:17 PM »
A few years ago I would have said to re-gear for sure.  Recently though my kid slapped a hand-me-down Weber 38 on a later model 22r in his '83.  The thing has so much more power than I am used to I can't even believe it!
He is running 4.10s with 33s and it will pull on my hot 20r with 5.29s.  Actually it runs circles around me.
So armed with this new and disappointing experience, I would say to try it out with the 4.37s.  Be sure to let us know how it goes.
If you aren't happy re-gear later.
– Steve McQueen
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #2 on: Nov 29, 2021, 08:24:34 PM »
You really don't need to regear with a dual case.    You can get your lower offroad gearing with the dual case.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Gnarly4X
  • Online Gold Turtle Award
  • Turtle Points: 5134
  • Male Posts: 4,259
  • Member since Jun '16
  • 4-wheeling vicariously.
    • Buy me some coffee
« Reply #3 on: Nov 30, 2021, 01:41:01 AM »
Selecting diff gears is about what RPM do you want for each transmission gear?
With your W56B and your current gearing and 34” tires in 4th gear your engine is turning 2975 RPMs at 70 MPH.  In 5th gear it’s turning 2380 at 70 MPH.
What is your peak torque at RPM now?
What would be the peak torque at RPM for a diesel swap?
Highway travel is my consideration.  On my 85 standard cab, I ran 33’s with stock 4.10 diffs.
5th gear was not usable for highway speeds.  In 5th gear my RPM was 2338 at 70 MPH – about 1,000 below my peak torque for my 22R.  I had to be in 4th gear at 2922 RPM at 70 MPH.  If I ran at 80 MPH, my RPM was 2672 in 5th gear – just at the beginning of my peak torque range and only usable on the highway with no head wind and on the flat.
As emsvitil said, off-road in 4-wheel drive, the dual cases will handle gearing requirements for practically any wheeling conditions.
Gnarls. :usa:
« Last Edit: Nov 30, 2021, 06:50:16 AM by Gnarly4X »
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #4 on: Nov 30, 2021, 02:01:59 AM »
What's the torque curve for that engine?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #5 on: Nov 30, 2021, 02:10:54 AM »
Considering the usual lower rpms of diesel engines, 4.30 might be the correct ratio.....................
 :think:
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
obrut [OP]
  • Male Posts: 18
« Reply #6 on: Nov 30, 2021, 04:21:38 AM »
thanks for the replies.  I noticed my pinion seems to have a little play in it so I was going to pull it apart.  I know that can of worms so I though it would be a good time to change the gears if I need to.  My truck is not a daily driver so it can sit until I fix the pinion.  My other though was if I keep the 4.30 gears then maybe I can find a 4.30 gear elocker to swap into the front and then take the front center section and put it in the back.
BTW is it 4.30 or 4.37 gears in the 1980 trucks?  I think the e lockers are 4.37, is that correct?
RUGER
  • Online The 1K Club
  • Turtle Points: 17605
  • Male Posts: 1,026
  • I love Marlin Crawler!
« Reply #7 on: Nov 30, 2021, 06:09:15 AM »
factory toyota pinons are color coated. if look threw the driveline yoke(or unbolt the driveline) the pinion will have a color from the factory. if i remember right pink was 4.10 and red was 4.3 but its been years, im sure there is someone on here that will know fer sure.
edit: http://www.4crawler.com/4x4/4R_TechInfo.shtml  toward the bottom it has the pinon colors
RUGER :usa:
« Last Edit: Nov 30, 2021, 06:30:08 AM by RUGER »
:usa: GOD BLESS AMERICA :usa:
"the hag" 83 toy with 5" all-pro lift, marlin crawler dual case #1011 and marlin hy-steer, 35s, 5.29's, exo cage, yada, yada, yada. she's back in black.
97 F250
84 Grand Waggy
77 Scout II SS
96 Explorer Sport
20 F150
USN SEABEE 2008-2012 :usa:
run with THE PACK 4wdc of los osos
NRA life member
obrut [OP]
  • Male Posts: 18
« Reply #8 on: Nov 30, 2021, 07:00:17 AM »
4.37 for sure, thanks
helipilot77
  • Turtle Points: 1018
  • Male Posts: 1,729
  • Member since Jul '12
  • Seattle, WA
    • My build thread
« Reply #9 on: Dec 01, 2021, 12:43:28 PM »
I’m currently running 4.10’s with 35’s in my diesel but I did prefer the 4.30’s I used to have in it with 31” tires. I am planning to install 5.29’s and 40’s which should put me close to where I was with the 4.30’s when I had 31’s. You may end up wanting something closer to a 4.56 if anything different at all.
Last post Feb 16, 2007, 07:18:41 PM
by BoG-ToY
Last post Jul 29, 2007, 04:29:56 PM
by *ROKTOY*
Last post Oct 26, 2007, 12:47:32 PM
by red
Last post Mar 23, 2015, 11:03:34 AM
by hamish_18
Last post Jan 12, 2017, 11:22:09 AM
by 85Buckett
