Author Topic: 4.7f-2.8r swapping order question  (Read 827 times)
ACLakey
  • Member since Oct '17
« on: Oct 07, 2017, 04:22:06 AM »
So I recently purchased an 87 Toyota with a 4.7 front case and 2.8 rear twin stick. In the past I had the same setup only in the reverse order, 2.8 front and 4.7 rear. Can I simply change the order of the cases or do I need to swap the internal components? I think from a mechanical standpoint I would rather have the 2.8 case in front.
Sent from my Pixel XL using Tapatalk
daniresch
  • Turtle Points: 930
  • Male Posts: 761
  • Member since Apr '11
Re: 4.7f-2.8r swapping order question
« Reply #1 on: Oct 08, 2017, 08:31:09 AM »
You can swap the housing that holds the gears front to back with the gears, and i would since the 4.7 already has its housing clearanced. But essentially you'll be tearing everything apart either way.
