Author Topic: 20r oil from breather filter  (Read 4638 times)
Yotaoverland
  • Male Posts: 208
  • Member since Feb '15
« on: Aug 12, 2015, 08:21:44 AM »
I recently did a minor rebuild on my 20r. Gaskets, seals and timing chain set up. A friend of mine suggested capping off the front breather hole on the valve cover and just putting a filter on the rear. Yesterday I noticed oil bubbling out of the filter. I assume I should not cap off the front hole?
I've noticed some guys put a hose from the rear hole to the air cleaner.
« Last Edit: Aug 12, 2015, 08:55:54 AM by colezombie »
1980 pickup LWB
22reperformance 22r
L-52 5spd
4.7 Tcase
Detroit Trutrac
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: 20r oil from breather filter
« Reply #1 on: Aug 12, 2015, 10:22:24 AM »
you may have blow by from worn piston rings or valve seats....
Yotaoverland [OP]
  • Male Posts: 208
« Reply #2 on: Aug 12, 2015, 10:43:04 AM »
I'm hoping that's not the case..
1980 pickup LWB
22reperformance 22r
L-52 5spd
4.7 Tcase
Detroit Trutrac
  • Male Posts: 8,707
« Reply #3 on: Aug 12, 2015, 05:34:20 PM »
if the baffle under the valve cover is there, there is really no reason oil should be splashing up and able to saturate that filter
Yotaoverland [OP]
  • Male Posts: 208
« Reply #4 on: Aug 13, 2015, 05:53:40 AM »
I'll check that. A friend of mine helped rebuild it, and I'm wondering if maybe it got taken off and not put back on.
1980 pickup LWB
22reperformance 22r
L-52 5spd
4.7 Tcase
Detroit Trutrac
Yotaoverland [OP]
  • Male Posts: 208
« Reply #5 on: Aug 14, 2015, 02:10:41 PM »
So today I was able to take a look at the truck. I went out and took the filter off the valve cover and the unblocked the front hole (pcv?)
and turned the truck on. I felt a decent amount of pressure coming out. I read some other blow by threads, some in which you commented.
You mentioned that engines are just a compressor and are sealed. Maybe I just have a bad pcv or baffle? I don't want to misdiagnose the issue
and end up blowing the motor.
1980 pickup LWB
22reperformance 22r
L-52 5spd
4.7 Tcase
Detroit Trutrac
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #6 on: Aug 14, 2015, 02:34:07 PM »
Put a hose and a catch can on it and see how much oil comes out.
A DIY version should be fine.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Last post Sep 05, 2007, 07:15:22 PM
by Glen1978
Last post Jan 14, 2009, 05:57:42 PM
by OOPS
Last post Mar 28, 2009, 02:10:06 PM
by V-Man
Last post Dec 18, 2012, 06:28:08 PM
by bng1
Last post Apr 23, 2019, 03:05:04 PM
by OOPS
