Well, they suggested that i use their long travel front springs which he told me are teh same length as stock 2nd gen rears. Hopefully that's correct! that way the only issue would bve the center pin which may or may not turn out to be an issue.
All pro front springs are on, fit perfectly. However, my rear springs are weird. I was under the assumption they were 63s, but they're not. Much shorter. Anybody know what they are?
63's are chevy. The toyota rears from all pro and tg are 56" or 57".
Hmmm, so what would be right under 55"? mine are obviously flattened out so with a right arch, they'd be even shorter eye to eye.
Newer Jeeps with coil springs do ride a lot better in almost every case compared to leaf springs. With 42 inch tires you should pretty much be able to run 0 psi and be ok, right?What shocks are you running? It sounds like you are getting an empty flatbed truck type of ride and not flopping around from having uncontrolled springs.
Thanks for the info. Measured correctly and they are about 56 5/8" which seems to be trail gears springs.
Started by 95TacoTruck General 4WD Discussion
Started by 87_Yotaman Trail Reports, Events, and Gatherings
Started by cruzila MCR8 (Sept 11-13, 2009)
Started by FireGuysRacing Desert and Sand Life
Started by I_is_a_moose New Member Check-In!
