Author Topic: lowering transfer case 2 inches to stop vibration  (Read 1778 times)
tyes
  • Turtle Points: -10
  • Male Posts: 238
  • Member since May '09
« on: Aug 04, 2014, 05:48:50 PM »
what is your thoughts? Lowering a TC 2+ inches to level out the rear driveshaft. My rear drive shaft measures 39 1/4 inches with double CV at is at 5+ inches leaves. More than likely use washers to do the drop.
86 T4R V8 1UZ-Fe
toyodaaddict
  • Turtle Points: 399
  • Male Posts: 1,147
  • Member since Sep '08
I think lowering the case is going backwards. Id lower the truck or focus on pinion angle. but if yor talkin tg style 5'' springs that are more like 7-8'' Id suggest lower lift springs
tyes [OP]
  • Male Posts: 238
Pinion angles are at 0* pointed directly to TC. i really hate to lower leaf springs.. hoping theres other options?
86 T4R V8 1UZ-Fe
toyodaaddict
  • Male Posts: 1,147
with a cv your pinion needs to be 2* under the slope of the shaft. from my experience just 1* off is all it can take to have problems
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
I did this in one of my builds and came to the conclusion that it would have been better to have lowered my truck or get the angles right to avoid the vibration. It did work though so as a band-aid fix it does work. I used tubing, not washers to achieve this.
toyodaaddict
  • Male Posts: 1,147
Lowering transfer cases is very much a jeep thing to do... just sayin :D
TheChewMaster
  • Turtle Points: 5
  • Male Posts: 245
  • Member since Feb '12
the reason for this is because the pinion will rotate up towards the bed upon loading the driveshaft (acceleration). OP in your setup, when loading the shaft you are probably pushing the pinion angle further up and forcing the driveshaft to be out of balance. Balance is key and only a tiny miscalculation in a shaft can cause a good vibration.
Last post Nov 20, 2005, 05:19:12 PM
by Marlin
Last post Oct 23, 2007, 01:17:01 PM
by mmessier2
Last post Jul 27, 2011, 08:35:49 PM
by Tyler+Ashleys4runner
Last post Oct 19, 2011, 07:19:17 PM
by poor boy pulling
Last post Nov 16, 2011, 01:34:45 PM
by tom85
