Author Topic: Need opinions on locker!!  (Read 2418 times)
CruelCrawler83
  • Turtle Points: -1
  • Male Posts: 87
  • Member since Sep '11
  • Cant find it Grind it
« on: Nov 25, 2012, 11:15:49 AM »
So i have plans on getting either a detroit or aussie locker to run in the rear. for the front im looking at the true trac limited slip. any opinions/ experience with one of these? how well do they lock up? are they strong? this is gonna be on my DD with 35s. i plan on running stock axle shafts in the front for now so thats why im looking at the true trac. are they safe to run with stock axles?? :eyebrow:
22rMudToy
  • Member since Nov '12
  • I will be mentally stonger than every opponent
Re: Need opinions on locker!!
« Reply #1 on: Nov 25, 2012, 02:24:54 PM »
I run spartans front and rear which use the same concept as a detroit. Off road i think they're the absolute best upgrade i love em. The only problem i ran into was when turning it'll chirp my tires in the rear and loud hard popping noises that would cause everyone to look. The way i fixed that was use Lucas 85w-140 heavy duty high performance differential oil and i never have any problems anymore.
1980 long bed p/u. Spartan lockers, 4.10 gears,
s, 261 cam, Redline Weber 38, K&N air filter, 2.5in exhaust with glasspack. 300 watt amp, 2x12in kicker subs, 2 tweeters, 2 5x7 sony xplodes/
Dont Tread On Me!! Iv stood toe to toe with some of the baddest joes you'll ever see but i never back away. Knock me down and ill stand back up screamin bring it on. My mind and heart keep me goin long after my body is tired from fighting.
Special Ops bound when my time comes
CruelCrawler83 [OP]
  • Turtle Points: -1
  • Male Posts: 87
« Reply #2 on: Nov 25, 2012, 09:08:50 PM »
is the spartan better than the aussie?
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
  • Member since Sep '10
    • Buy me a cigar
« Reply #3 on: Nov 25, 2012, 09:52:32 PM »
Arguable, I'd look for a full case locker like a Detroit or grizzly for the rear. Limited slip up front is one and will help save your axles, but look for one out of a supra irs (I believe) as they could be cheaper.
2manytoys
  • Turtle Points: 490
  • Male Posts: 583
  • Member since Nov '09
« Reply #4 on: Nov 26, 2012, 09:29:25 AM »
My truck had Tru-Trac's in both axles when I bought it. Worked great on snowy roads and in sand. Sucked for rock crawling.
I put an Aussie in the rear of my son's truck and his truck out crawled mine even with his open front diff.
I'm now running Aussies in both axles and they work great.
A full case locker like a Detroit was out of my budget. I got two Aussies for less. I'm only running 35's so no problems so far.
CruelCrawler83 [OP]
  • Turtle Points: -1
  • Male Posts: 87
« Reply #5 on: Nov 26, 2012, 11:14:48 AM »
Will i have problems breaking stock birfields with the aussie in the front? and how is the turning with the aussie in the front?
NorCalPR
  • Turtle Points: 2
  • Male Posts: 223
  • Member since Dec '08
  • NorCal TTORA Prez
« Reply #6 on: Nov 26, 2012, 11:17:02 AM »
You won't have an issue breaking birfs. I'm running a lock right in my v6 carrier in the front and it's been fine for 4 years. Last gear install I inspected it and it still looks new.
Turning will suck unless you have ha or twin sticks
"W6FTW"
NorCalPR
  • Turtle Points: 2
  • Male Posts: 223
  • NorCal TTORA Prez
« Reply #7 on: Nov 26, 2012, 11:51:47 AM »
Let me rephrase, you'll break the birf first before the lock right/Aussie. Stock birfs you will probably break them
"W6FTW"
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
    • Buy me a cigar
« Reply #8 on: Nov 26, 2012, 12:16:31 PM »
Yes you will brake stock birfs, unless you turn out your steering stops a little bit. Steering is fine with a front locker except if you're going down hill and turning, then it sucks.
2manytoys
  • Male Posts: 583
« Reply #9 on: Nov 26, 2012, 04:20:15 PM »
Even with a stock open front diff, you have more steering effort when you are in 4wd. It is slightly more noticeable with the Tru-Trac and the Aussie.
I'm in Az desert terrain so usually some loose dirt, rocks under my tires. I haven't experienced the horrible steering some people report. I'm running Dirty 30's also. I was told I WILL break stock birfs with 35's and bigger. Didn't want to go down that road. Also twin stick.
Last post Jan 27, 2004, 08:01:19 PM
by tribliska
Last post May 22, 2004, 09:31:09 PM
by Hyena
Last post Jan 29, 2005, 06:33:47 PM
by Skinny_Pedal
Last post Feb 11, 2005, 10:35:05 AM
by BLUCRUZ
Last post Dec 20, 2009, 11:46:38 AM
by NCK4L
