Author Topic: Oil Leaks!!! Timing cover won't stay sealed!  (Read 1259 times)
Lonestar Honcho
  • Member since Feb '06
« on: Dec 08, 2010, 10:56:18 AM »
What am I doing wrong? I am about to embark on the THIRD time of trying to seal my timing cover. I don't know what I'm doing wrong.
Is this really supposed to be this hard? I'm using the regular sealant from O'Reilly's. I have even let it sit a night or two before I ran the engine.
I'm thinking of going to the Toyota dealership and getting OEM brand sealant. I even have a brand new timing cover to match the motor.
Does anyone have any tips or advice for me? Thanks. :smack:
DD '82 Toyota 4WD LWB, L-52HD, 31" BFG's, 3" Skyjacker, Orig. Blue paint with AC.
Sparkplug
  • Turtle Points: -130
  • Male Posts: 2,046
  • Member since Jan '08
  • Doin it Standing Up
Re: Oil Leaks!!! Timing cover won't stay sealed!
« Reply #1 on: Dec 08, 2010, 11:01:14 AM »
where does it leak from? did you get the right cover? Ive always used gray sealant, and it has worked everytime.
Edit: i apply thickly all around bolts and where it would sit, snug all bolts lil tighter than hand tight, let it sit for like 20 min, harden gasket, then i torque it down.
Lonestar Honcho [OP]
« Reply #2 on: Dec 08, 2010, 07:20:12 PM »
Yep I'm using same stuff. Guess I'm over doing it.
Maybe third times a charm... :crossed:
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #3 on: Dec 08, 2010, 10:09:17 PM »
Are you sure it is the cover and not the crank seal? If the harmonic balancer (front pulley) has a groove worn it it the seal will not seal. Oil will leak and be thrown out by the balancer.
Sparkplug
  • Male Posts: 2,046
« Reply #4 on: Dec 08, 2010, 10:27:55 PM »
yes this is very true, being i have same prob in my 85, thats the only spot it leaks from. Where can one get a new front pulley, ive tried searching rock auto, but maybe im looking in the wrong section?
edit, found it, 65 bucks
« Last Edit: Dec 08, 2010, 10:34:06 PM by Sparkplug »
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
« Reply #5 on: Dec 08, 2010, 10:53:41 PM »
It sounds to me like his timing chain cover is what's actually leaking, where it mates to the block, and is either warped or cracked.  Either way, it sounds like you're doing it right, worked for me on a few truck and street bike engines, but you shouldn't have to goop it on, and too much is as bad as too little.  You want a thin bead.  Ultra gray should work fine, but toyota fipg is great stuff and well worth it too, made my pan gasket out of it on my latest engine and it's yet to leak in the last couple years  :thumbs:
Last post Jan 04, 2005, 07:29:49 PM
by toyoder
Last post Jun 23, 2004, 09:13:55 PM
by Jared
Last post Nov 22, 2004, 06:21:49 PM
by norcalyoter
Last post Aug 19, 2007, 11:20:21 PM
by MUDSLINGER
Last post Jun 10, 2022, 11:14:56 AM
by slowpos
