Hi, I was wondering what you guys think of the possibility of using All-Pro 6" rear springs (run as spring under) for a mild prerunner setup? This would be going in an '86 Pickup that will probably get a Blazeland front setup (or TC if I can scrape up the cash). It will get used as a DD and will mostly be used on back country roads in MN and SD so I am not too worried about landing massive jumps, but more stable performance on rutted out and washed out back roads. I need longer travel and a softer ride than stock, but I also like to roll things so keeping the CG low is pretty important to me. The truck WILL get rolled at some point, but if I can lessen the chances that would be good. I figure with a 6" lift spring but converting to spring under I should end up at about stock ride height. Anybody have any thoughts on this setup at all or have any idea of how much travel I can expect? Any pictures of the 6" springs?
