Hey all, I'm finally going to tackle my ignition problem with a upgrade I was told about here on Marlin.
"The Rock", who also owns a Hilux PM'd me a way to use a '77 GM HEI style ignition module in place of the ignitor that sits under the coil.
I recently PM'd The Rock back to ask a couple more questions and am waiting for his response.
I'm doing this because I recently have gone through one other good ignitor in place of the original. It lasted a couple of months with no problems.
Has anyone else thought or heard about doing this?
My questions to The Rock are basically wiring related. The new module has only four spaded locations for wires whereas I have six wires. Maybe it would be better explained if I posted The Rock's PM to me...
"1st the module - I am using a "Niehoff"p/n DR 400CS for a 77 camaro 350 HEI distributor. The module has to be mounted on a aluminum heat sink w/ a coating of dielectric grease between the module and heat sink( for heat dissapation) the block of aluminum will mount to the inner fender of the truck near where the igniter used to live.The aluminum block needs to be slightly larger than the new module.
There are 4 terminals on the GM Module "B, C,G,W"
B terminal goes to 12 volt (pos side of coil )
C terminal goes to ign power( neg side of coil)
G terminal-TO DISTRIBUTOR
W terminal-TO DISTRIBUTOR
The G and the W terminals will attach to the pink/white wires from the distributor .These used to go to the igniter. You will need some zip ties, 4 female spade connectors, some butt connectors(2) and some 12 g wire. It is VERY IMPORTANT that the wires from the distributor( pink/ white) going to the GM module (G,W) are INSULATED AND ROUTED AWAY FROM THE EXHAUST!!.."---The Rock
My question is do I double the wires on each of the spade connectors for the B terminal (12 volt and pos side of coil)? And double the wires for the spade connector for the C terminal (ign and neg side of the coil)?
Thanks for reading and helping a Toy fan out!
![Beer Chug\'n :beerchug:](https://board.marlincrawler.com/Smileys/marlin/beerchug.gif)
