Hi,
I am upgrading to a geared transfer case, from a chain driven on my 91 V6 pickup. The adapter plate between the transmission and the tcase makes the drive train a 1/2" longer. I was wondering how much needs to be changed?
I have a full length spline on the front drive shaft, so that's ok.
I lifted the suspension from 3" to 4", so there should be bit of play at the diff end of the drive shaft.
I noticed the centre support bearing mount has a slot, is this enough to shift it back 1/2".
So I think the only serious mod is the cross member/tcase mount. I need to replace the mount (cracked rubber).
Is the 4x HD tcase mount a weld on (could make life a bit easier)? Or is the OEM geared tcase mount already suitable?
What have others done with the 1/2" shift back?
Cheers,
Michael
