Author Topic: trans codes  (Read 1830 times)
mtntoy
  • Turtle Points: -84
  • Member since Jan '04
  • whats the worst that could happen
trans codes
« on: Oct 03, 2004, 04:37:46 PM »
what do the letters following the a340 series trans represent?  I am curious be cause I am looking to put a 1uz in my fj55 and want to know about half cuts and which one to get.  Does the e stand for ect?
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
Re: trans codes
« Reply #1 on: Oct 05, 2004, 09:36:27 PM »
Sorry, but I had been unable to get a solid answer from any juice trans builders that I have spoken to.
Marlin
mtntoy [OP]
Re: trans codes
« Reply #2 on: Oct 06, 2004, 06:40:36 AM »
alright, thanks for the post any way
  • Administrator
  • Turtle Points: 2205
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
Re: trans codes
« Reply #3 on: Oct 06, 2004, 08:40:08 AM »
Yes, I've got your answer.
H is the code for hydraulic transfer, F is the code for mechanical transfer case, and E is the code for Electronic Controlled Transmission, which is only found on 2WD 4Runners and some other models I believe...
« Last Edit: Oct 06, 2004, 08:44:26 AM by BigMike »
UNBREAKABLE
  • Turtle Points: 372
  • Male Posts: 2,028
  • Member since Aug '04
  • Yeah, I guess you could say I'm a RockStar
Re: trans codes
« Reply #4 on: Oct 09, 2004, 09:56:45 AM »
I have an a340H if you are interested
That's how I roll
mtntoy [OP]
Re: trans codes
« Reply #5 on: Oct 12, 2004, 05:11:21 PM »
Thanks for the info Mike
Last post Mar 12, 2008, 07:29:23 PM
by BLACKDOG
Last post Oct 15, 2005, 02:44:47 PM
by BLACKDOG
Last post Dec 22, 2005, 10:02:03 AM
by dov'd85
Last post Mar 26, 2007, 06:36:07 PM
by 86 4runner
Last post May 16, 2007, 10:01:45 PM
by toyrunner87
