Reply #1 on: Apr 06, 2009, 02:20:23 AM »
No, to begin with it is 4 1/2" too short and the bolt holes would not line up.
You could reuse the larger '84 and newer slip yoke assemble and slip it on the '80 shaft and drill out the 4 c/v joint bolt holes with a 13/32 drill but the shaft is still too short.
Hope this helps,
Marlin
![](https://board.marlincrawler.com/Themes/MCI_V3C/images/ip.gif)
Logged
