Originally posted by Mudjunky13:[QB] check the front countershaft bearing. i've not seen this on that exact trans. but have seen it on other toyota 5sp trannys. the cage holding the balls separated can come apart letting the shaft move over enough to cause noise and eventually gear damage. fourth doesn't make noise because it goes straight through and doesn't load the countershaft. older model trannys have a shorter input shaft and bellhousing that i don't think will work in a tacoma, they also have the slave cyl. mounted on the pass. side instead of the driver side. hope some of this helps. [/QB]
4th gear input runs all the time, even in revearse, thats why you hear it in every gear except 4th and 5th. you dont hear it in 4th because you're actually using it and its not free running-it doesn't effect 5th gear.
I had replaceed the clutch, t.o. bearing, PP before this thread. I went with a low milage p-n-p tranny.... cured the prob. Still spent 650.00 and sat though. Well worth being rid of the god awfull whine though.-Josh
p-n-p tranny?
Started by 1Bad4Runner General 4WD Discussion
Started by JJ3 Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by JJ3 Engine
Started by dntsdad Parts Wanted
Started by alfio Engine
