Author Topic: Need help on Tranny Swap Auto to Manual  (Read 1731 times)
x2nou
  • Member since May '08
« on: Nov 17, 2008, 11:21:51 AM »
I did a Manual tranny swap to my 85 4runner and need help on the wiring. I notice that the manual tranny has only two sensor one is the oil sensor and i think the other one is a 4x4 sensor indicator. i have a dual case on too. Well the plug does not match the auto tranny plug and how do i know where they go; and does the other wire affect the truck at all if its not plug in.
Please some on HELP
gnob
  • Turtle Points: 486
Re: Need help on Tranny Swap Auto to Manual
« Reply #1 on: Nov 17, 2008, 03:26:08 PM »
the two wire plug on the trans is the reverse lamp switch.
the single wire on the t case is the 4wd lamp.
you are going to have to mod the wire from the auto harness so you have a nuetral switch closed so the starter will work.
search for the wiring manual and have fun.
hold this. . .
x2nou [OP]
« Reply #2 on: Nov 17, 2008, 08:49:35 PM »
hay thanks; but my sensor on the top of the t-case has two wire not a single. Do i need to change the ECU to a 5speed ECU?
x2nou [OP]
« Reply #3 on: Nov 22, 2008, 09:25:27 PM »
problems solves Thank.
Last post Dec 14, 2004, 08:57:25 PM
by reklund5
Last post Aug 15, 2005, 10:59:36 PM
by gturismo
Last post Feb 25, 2008, 04:37:52 PM
by Teamsobaco
Last post Sep 27, 2006, 02:49:50 PM
by johnnygalt
Last post May 29, 2010, 12:51:31 PM
by chim
