Cleaning out the garage, and looking to get rid of a few things. I'll update the list as I find things.
SR5 Guage cluster from an 86-$40
Stock Solid Axle draglink for push pull steering-$10
2 Stock headlights from a second generation truck-$10ea.
4cyl. carrier with a blown lock-right-$10
Open highpinion carrier with bearings (2 pinion design)-$20
Open v6 Diff. W/4.10 R&P. It's missing the bearings, and would need assembly comes with an open four pinion carrier.-$50
2wd W56 transmission-$50
Stock Solid Axle Steering arms-$25 for both
2" Lift Blocks (2 sets)-$15/set
Transfercase Mount-$10
1 set of Bellfields $85ea. or both for $160
2 shortside inners-$20ea.
2 longside inners-$15ea.
If you are interested in a longside and a short side, then $30 gets you both.
I could work a deal for the Bellfields and inners. $220 buys you all four inners, and the two Birfs.
Let me know if you are interested. Thanks.
