Unbolt the 4 nuts that hold the axle/brake drums on, the axle/drums should slide out and back in pretty easily. If the rear is bent it will be extremely hard to slide out of the carrier because of all the tension and it is nearly impossible to get back in because once the splines line up the 4 studs at the end won't.
