Author Topic: help with drain plug, starter bolts  (Read 1778 times)
n.c.84
  • Turtle Points: 15
  • Member since Jun '05
« on: Jan 08, 2007, 04:16:45 PM »
yea...im missing a drain plug on my 84 t-case. also finishing up on new motor swap and new 22r motor doesnt have bolts for the starter motor. these are random and hoping someones has some spares around. im at 1063 crosscut ct. bend or. 97702. will pay all expenses. thanks yall.
89 toy
  • Turtle Points: -1198
  • Male Posts: 383
  • Member since Dec '03
Re: help with drain plug, starter bolts
« Reply #1 on: Jan 08, 2007, 04:52:06 PM »
the starter bolts to the bellhousing on the tranny
http://www.marlincrawler.com/htm/diff/pickup_diff.htm all the way at the bottom they will work for the tranny also $4
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
« Reply #2 on: Jan 09, 2007, 03:50:40 PM »
On the tranfer case parts and accessories page :thumbs:
http://www.marlincrawler.com/htm/transfercase/tcase_ac.htm
Another 4 bucks :thumbs:
Also, if you want to take advantage of the low profile and you're  not needing it on the t-case per say, you can swap your stucok plug off one of your axles to the t-case, and run the low pro plug on the axle.
              -Ronald Reagan
DAWGTOY
  • Turtle Points: 460
  • Male Posts: 212
  • Member since Jul '04
  • aint too old & broke up to sit down yet
« Reply #3 on: Jan 10, 2007, 09:20:46 AM »
hey 84. what you doin so far from nc?
hope things are well with you.
if you was near me i got all you need.
later
dawg
1983 TOY SHORT PICKUP .35/12.50S EXO CAGE HOMEMADE BED CAMO PAINT, REARS UP FRONT CHEVYS IN THE REAR, 4 WHEEL DISK, CABLE LOCKER REAR, LOCK RITE FRONT, 5.29GEARS FRONT & REAR.BOBBY LONG 30 SPLINES 9500 lb WARN WINCH. DUAL
T CASES WITH 4.7 IN THE REAR. THANKS MARLIN
n.c.84 [OP]
  • Turtle Points: 15
« Reply #4 on: Jan 10, 2007, 03:00:30 PM »
thanx guys....called marlin and everything will be here in two days. man there good!
Last post Jul 06, 2004, 02:23:29 PM
by superstarai
Last post Apr 11, 2006, 10:32:22 PM
by wa4x4
Last post May 04, 2007, 09:48:07 AM
by All_Set
Last post Jul 09, 2007, 10:39:38 PM
by jimbo74
Last post Aug 08, 2020, 02:00:46 AM
by Gnarly4X
