Author Topic: Taco Tranny for 7M-GTE Swap?  (Read 3198 times)
wrenchtech
  • Turtle Points: -14
  • Member since Jan '04
    • WrenchTech: Content for Backyard Fabricators & Homeshop Mechanics
« on: Jan 27, 2004, 08:53:30 PM »
Anybody know any reason why a Taco tranny (1996+ R150F) would not work behind a 7M-GTE using the Supra R154 bellhousing ?   Input shaft length is nearly the same as the R154 and the spline is the same , right?
I believe there is a Marlin Crawler t-case adapter to get a gear type t-case onto the back of the Taco tranny.
1999 4runner SR5, 3.4, auto, Horizon Blue
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
Re:Taco Tranny for 7M-GTE Swap?
« Reply #1 on: Jan 27, 2004, 09:20:54 PM »
The clutch disk is the same 29 spline and the input should work along with the orginal pilot bearing. :beerchug:
I have been selling the billite Tacoma to gear driven t-case adapter for three years now.
Marlin
supratruck
  • Turtle Points: 416
  • Member since Dec '02
  • I love Marlin Crawler!
« Reply #2 on: Jan 27, 2004, 09:37:00 PM »
Isn't there a 1/4 inch difference in the input shaft lenght?  There's a post around here that give the input lenghts. I think the '96 and up R150 is longer that the Turbo Supra R154.
dok33
« Reply #3 on: Jan 28, 2004, 11:06:54 AM »
Not to get this post off topic, but about how much hp/tq can the taco tranny hold?  This would definitely be a sweet setup if you could put it behind a built 7mgte pushing 400-450hp considering that can be cheaply and easily accomplished!
'87 4Runner 4.3 swap, SAS in progress
Marlin
  • Male Posts: 856
  • MC³ = 1,148:1
    • Marlin Crawler
« Reply #4 on: Jan 28, 2004, 08:24:58 PM »
I have never worked on or have had a 7M-GTE trans in my shop :(
If the truck is around the factory weight, The R150F should take the power if driven decent.
Marlin
reklund5
  • Turtle Points: 286
  • Male Posts: 1,263
  • Member since Nov '03
  • I love my Marlin Crawler!
« Reply #5 on: Jan 28, 2004, 09:17:27 PM »
I've got a 400 7MGTE, and there was NOTHING cheap or easy about it.  But I've got one helluva fast 3rd Generation Supra...
reklund5
  • Male Posts: 1,263
« Reply #6 on: Jan 28, 2004, 09:19:45 PM »
Uh, make that 400 HP 7mgte...sorry.
Last post Jul 28, 2007, 08:48:22 PM
by gtoyonrocks
Last post Mar 21, 2010, 11:51:43 AM
by 79coyotefrg
Last post Sep 21, 2009, 10:15:12 PM
by Makohon
Last post Oct 30, 2009, 01:21:09 PM
by motorider228
Last post Oct 29, 2011, 08:59:11 PM
by Mollydawg
