Well not what I thought I saw, but I found this....
there is a how to on swapping those gauges from Barney that I used, it was very straighforward, just required pushing out pins and moving them around - and adding a tach wire. But this is simply a SR5 swap, not different years..
For the record, here are the pinout of SR5 vs non-SR5 gauge for 83:
SR5 non-SR5 wire color function
1 1 GY Right turn signal indicator
2
3 3 BR (B BR) Speed sensor (-) ground
4 6 GL Speed sensor (+)
5
6
7 23 YG Water temp gauge
8 9 RW Panel lights (+)
9 15 YR Fuel Gauge
10 12 Y Ignition switched power
11 21 YB Oil Pressure switch (idiot light)
12 22 YW Charge (idiot light)
13 14 WB Ground
14 Tach input - must be wired to igniter
yellow
15 17 GB Left turn signal indicator
16 16 RB Panel lights (-)
17
18
19 11 G 4WD
20
21 19 BY Seat belt
22
23 13 RG High Beam
24 20 GW Brake
You might be able to do it.
