I did it with my 3rd gen. Look up my build. With second gens, you probably don't have to add a body lift to clear the fuel tank and frame rails thoughSent from my LG-H830 using Tapatalk
You will have to move the rear cab mounts. Front mounts at a pillar and core support are the same.
How about the bed? I need to move the supports to? Sent from my iPhone using Tapatalk
Bed has to be modified(bobbed in front) front bed mount needs to be cut off and body lift is needed because the horse collar (mine was a 4runner frame) and the rear mount needs moved.
