If you don't get a matching cross member you lose the clearance gained by rotating the case.
Wrong! The 10 degree case rotation gives you drive line clearance not t case clearance
You're absolutely correct that by raising the driveline you'll get more driveline clearance, but I thought the 10 degree rotation also raised the low point of the t-case a bit and that with the right cross member you could gain a little belly clearance.
.ive retubed my rear dl 4 times in the last year from bashing it on rocks.the only solution i can see for the rear is a 4 link so you hit the links instead of the drive line
The skid plate still mounts in the same location so you dont gain any ground clearance and the rear driveline is still a problem.ive retubed my rear dl 4 times in the last year from bashing it on rocks.the only solution i can see for the rear is a 4 link so you hit the links instead of the drive line
The FROR crossmember would that give you drive line vibration as its solid mounted then only rubber on the outside chassis mount. I've email bud built await g a reply
Thanks for that black diamond
What are you wheeling? I went to a 1-piece DL on my ex-cab, bent 3 in a season. Went back to a 2-piece no more problems, I made my own center bearing mount and use a "pillow Block" bearing instead of the POS stock bearing.
Started by Matt G Parts For Sale
Started by Snow Leopard Parts For Sale
Started by robrub00 Parts For Sale
Started by nor-cal yota Toyota Pickup/4Runner Tech 1979-95
Started by ajordan1975 Parts Wanted
