What is the trick to getting the oil seal off the back of the hub to be able to remove the inner wheel bearing? The FSM manual says pry with a large screwdriver, but brute force is not doing the trick even with a block of wood used as leverage.
Anyone know of a trick?
Take a brass punch and tap out the bearing race, it will remove the race, bearing and seal all at once
