Author Topic: check engine light  (Read 3120 times)
yotarunner85
  • Turtle Points: 6
  • Male Posts: 166
  • Member since Nov '09
  • San Diego, CA
Re: check engine light
« on: May 17, 2011, 04:35:27 PM »
Uh, no. I want it to be fixed right so the light comes on when something goes wrong, and it won't pass inspection without a check engine light. That's one of the things they check.  :smack:
If you want it fixed right then put the correct ECU in your truck. I don't think a resistor will work because the signal the ECU gets from the O2 sensor varies from 0 to 1 volt. If the Ecu doesn't see a varing voltage from the O2 sensor it will turn the engine light on.
1985 Toyota 4Runner, BFG 35" MTs, 4" lift, Detroits lockers front & rear,5.29, V6 rear, rebuilt 22RE.
Last post Oct 15, 2002, 01:02:17 PM
by dan_b
Last post Sep 20, 2005, 12:02:20 PM
by GrimReaper
Last post Dec 01, 2006, 11:26:13 AM
by spacoli
Last post Dec 12, 2006, 01:23:28 PM
by BLACKDOG
Last post Nov 25, 2010, 10:20:44 AM
by 4RunnerChevy
