Author Topic: 83 22r rejecting oil filters  (Read 11454 times)
BoG-ToY
  • Turtle Points: 594
  • Male Posts: 2,122
  • Member since Dec '05
Re: 83 22r rejecting oil filters
« Reply #90 on: Feb 08, 2011, 10:25:57 PM »
IF there is any exposed metal on those gally plugs still.. AND YOU ARE VERY COMFORTABLE with an oxy torch and have one.... pinpoint heat the plug and quench with WAX....
I wish I woulda been here before you did the head, I woulda told you with the head OFF to apply pressure to the outlet hole of the oil filter housing and make sure it came out the oil gally that heads to the head. IF you want to consider it, its risky, but you could pull the front passnger side headbolt and test the same, BUT when DONE you have to make a small tube to suck ALL OIL out of the bolt hole...but it would tell you if the oil is making it through the galley that goes to the head
Sand, what fun, drop pressure to 12psi, stock tires are still digging, can't afford to get stuck, 8psi, still not working. Find a place to GET OUT, air up, un-lock hubs,  WAIT whats this, hubs are UN-LOCKED already. 2wd, 8psi, stock tires, Oregon sand dunes.
Last post Aug 08, 2009, 06:32:19 AM
by unclejpl4x4
Last post Apr 13, 2007, 03:16:26 AM
by topar
Last post Jul 17, 2010, 01:12:13 AM
by bleakhorizon
Last post Apr 15, 2022, 04:21:55 AM
by Gnarly4X
Last post May 16, 2011, 04:17:22 PM
by blackdiamond
