so that means your not getting fuel, check your pressure before the fuel rail, I'm not sure where there is a port on that one, open your fuel tank door and take the cap off. have someone stand next to it and turn the key on, you should hear the pump prime if not bad pump or no power to pump. Get a dmm and check for bat voltage at pump, if so change pump or find open.
It will turn on when i squirt fuel into the upper manifold.
