Specs on Hella 700FF
# Jumbo Size
# Light-Weight Design
# Clear Glass Lens
# Bounded Water-Tight Lens Assembly
# Aluminum Vapor-Coated Reflector
# Sturdy, Shock-Proof Housing
# Light Comes Directly from the Reflector Providing Precision and Performance in the Light Output
# H3 12V/55W Bulb
# Dimensions: 8-5/8 x 7-3/8 x 3-1/2 inches
Specs on KC
Daylighter kit comes with two 6-inch Round Daylighter Off-Road lamp housings, a fully assembled wiring harness, two 100W halogen long-range bulbs, which are 200,000 candlepower beam per light, and a pre-terminated wiring harness with a 40-amp relay and an in-cab control switch. Daylighter Off-Road Lights use a heavy-duty rubber gasket, or bulb holder, that isolates all the elements of the lamp, including the lens, the reflector, and the bulb, from the vagaries of weather. The kits also include a patented shock mounting system, updated so that it requires no extra drilling. This shock mounting system isolates the lamp unit from the mounting bracket, or surface on which the light is mounted, to reduce lamp failure due to vibration. It's a shock mount that can endure the extremes of off-road racing. With its 1/2" posts these shock mounts install most anywhere. The kit also includes two yellow "smiley face" lamp covers.
Daylighter Long Range Light with Shock Mount Housing
6 in. Round
Clear Lens
100 Watts
Includes DIY Wiring Kit
Pair of Lights
These are some information I pulled from sites. Needs to grab it when I head to shop. Thanks PM me if your interested, ONLY GOT TWO KC KIT LEFT.
