Author Topic: need r151f help  (Read 1758 times)
dniel
  • Male Posts: 194
  • Member since Feb '09
Re: need r151f help
« on: Nov 14, 2010, 03:24:59 PM »
I think the two would be different. The thing that makes a 4wd r151f special is the tail housing so the 2wd version is not good for much. I think the way to convert it would be to get a tail housing from a blown up r150 for cheap and swap it on. You then need an adapter from marlin or inchworm to mount the gear driven case. Do your homework first as I have not done this but it is theoretically possible. You might also need a 23 spline gear set as I'm not sure if they make a 21 spline adapter. In short you are probably better off using the g52 or upgrading to a w56.
  Before you scrap the r151f see if it has the lower first gear set. These are getting hard to find and might be worth something to someone.
1uz-fe, 1 tons, 44" tsl
Last post Oct 07, 2002, 03:43:14 AM
by drybone
Last post Nov 26, 2004, 10:15:34 AM
by jr9162
Last post Jan 25, 2005, 01:54:25 PM
by superstarai
Last post Apr 21, 2006, 07:52:26 AM
by UNBREAKABLE
Last post Jun 20, 2012, 04:32:59 PM
by Redd
