Author Topic: 22re will not start  (Read 5224 times)
GNasty 82
  • Turtle Points: 994
  • Male Posts: 206
  • Member since Nov '09
  • Get Nasty!!!
Re: 22re will not start
« on: Sep 08, 2010, 02:48:50 PM »
I'm going to have to say that, unless it has bad gas, that the problem is spark related.  That being the case, the orange looking arc says a lot.  The question is, is the arc orange on all plugs, or just one of them?  You can eliminate more components by moving further up the spark trail.  Use the screwdriver technique I mentioned above on the plug wire coming from the coil, just unplug it from the distributor.  If you are getting an orange spark from the end of the coil wire to ground the, at least you know that the cap/button/plugs wires/plugs are probably OK.  Then the remaining suspects are the coil/igniter and the points and condenser.  I'm not actually sure if the '85 modal 22RE even has points and condenser.
Another thought that just popped in my head, since the cap and button were recently replaced, if you haven't already, make sure there is no water or other trash in the cap.
82 Toyota SR5 Pickup
  Marlin Dual Ultimate
  Front 5.29 LC HP Elocker
  Rear 5.29 Grizzly Locker
  BFG 37" KM2s
  Custom rear frame and flatbed
  Propane Powered.
Build Thread:
http://board.marlincrawler.com/index.php?topic=64521.0
"The two enemies of the people are criminals and government, so let us tie the second down with the chains of the Constitution so the second will not become the legalized version of the first."-Thomas Jefferson
Last post Feb 22, 2003, 04:07:53 AM
by BigMike
22RE won't start
Last post Sep 27, 2005, 06:36:54 AM
by RHG
Last post Feb 01, 2006, 11:08:04 AM
by toymech
Last post Jan 18, 2011, 08:30:54 PM
by dgrant71
Last post Sep 01, 2012, 08:21:17 PM
by 4Runner_guy
