Looks like I fixed it. A buddy came over today, and watched while I turned the steering wheel. The front U bolts where loose enough to let the front axle move on the leaf spring on the drivers side. I jacked it up and removed the U bolts to check the bolt in the center of the spring for damage, and everything looks good. I put it back together and made sure everything was tight under there. Seems to be fine now. Dean
