Author Topic: Please Help - Head Gasket Discrepancy - 84 22R  (Read 2505 times)
i_luv_my_truck
  • Turtle Points: -48
  • Male Posts: 157
  • Member since Mar '05
  • Toyota Crawler
    • My Rig
Re: Please Help - Head Gasket Discrepancy - 84 22R
« on: May 30, 2009, 09:19:35 PM »
i looked into this a few years back, the holes in red arent supposed to be open, i was told the holes are in the block to allow the sand when the blocks were cast to be washed out
i DID punch a head gasket out one time where you have the red and ran it BUT  i burned up my number 4 piston,  the way the water goes thru the engine it comes out the bottom of radiator into engine, thru the wp, flowing thru the block towards the rear of the engine where it comes up into the head and flows back towards the front
it is a slight side of the cylinder uptake where you see the water jackets around the block
I only run Toyota  or Rock Product head gaskets
Thanks for the explanation about the sand and casting.  It makes sense.
You write "burned up my number 4 piston" do you believe that was due to you punching additional water outlets?  What is a burned piston? i've never heard of that.  i've heard of a burned valve.
1977 Toyota Hilux 2wd - because because
1980 Toyota Hilux 4x4 - restoration project
1981 Toyota Trekker - nostalgia
1982 Toyota Hilux 4X4 LB - just because
1984 Toyota Hilux 4X4 - everyday driver
2001 Toyota MR2 Spyder - for speed
1993 Toyota Previa - for relaxing
http://www.cardomain.com/ride/2093325/
Last post Sep 24, 2004, 09:28:26 AM
by BigMike
Last post Apr 05, 2005, 12:57:07 PM
by Rebeltilldeath3
Last post Dec 24, 2006, 08:53:10 AM
by RTA
Last post Apr 02, 2007, 06:10:23 PM
by 82 HiLux
Last post Apr 26, 2007, 10:56:32 PM
by jimbo74
