Author Topic: Need help 5VZ-FE into 85 extracab frame  (Read 1549 times)
Mountain Yoat
  • Member since Sep '04
Re: Need help 5VZ-FE into 85 extracab frame
« on: Dec 30, 2004, 01:43:41 PM »
 8) thanks again :bowdown: I am using motor mounts I cut from a pre 95 IFS and I have accounted for the fact I may have to lower the engine some more. Would like to stick it at a 3" body lift not 4".  I also intend to use a simular motormount design to the LC engineering 22r/re mounts (Tube, polyurathane, sleve and bolt, Can't twist em off the rubbers) hoping to lower the engine 1" more in the process.  I'm using a 1985 Rad support with a four inch lift under it right now to help establish engine (Motor mounting height) but will only tack weld mounts til I get running gear under the thing. I know, I probably should get the running gear under it first but I think I will also be needing to put a remote oil sump in her.
So now I can go get me a 3.0 rad and fan shroud :laugh: This is a good thing Donkey
Last post Jun 17, 2010, 02:28:23 PM
by Toyota+in+Florida
Last post Jan 07, 2005, 01:51:48 PM
by MUDDONKEY
Last post Jul 31, 2006, 01:22:47 PM
by 85yoda
Last post Dec 04, 2012, 06:00:48 PM
by webilt
Last post Jul 22, 2022, 05:28:23 AM
by lone walker
