Author Topic: ENGINE CUTS OUT. *UPDATE HELP*  (Read 3452 times)
SLIVER
  • Male Posts: 503
  • Member since May '06
  • ))--SLIVER-->
Re: ENGINE CUTS OUT. *UPDATE HELP*
« on: Mar 27, 2009, 01:38:14 PM »
So my runner has been cutting out again BAD!
And needless to say i'm pissed.
I checked the TPS spec's this is what I found. Here are the spec's off the link, and my spec value will be off to the side in red.
Table 1: 22RE (2.4L-4 cyl) - TPS Adjustment Specifications
1. 0.00mm (0.000")    VTA - E2    200-800  123
2. 0.57mm (0.0224")   IDL - E2    < 2.3K  0.1
3. 0.85mm (0.0335")   IDL - E2    Open / Infinite open
4. Wide Open Throttle VTA - E2    3.3K-10K  7.72
5. n / a                    Vcc - E2     3.0K - 7.0K  6.73
Everything was in spec except #1 and the truck is still running like poo. cutting out about mid way in the throttle.
Do you think that I got a bad TPS or something?
I can adjust #1 until it is about 774, but then #3 reads .1 ish instead of open.
All I know is I'm just about to the point that I light this thing on fire, i'm getting so frustrated.
What should I do now?
Please help me.
))--SLIVER-->
« Last Edit: Mar 27, 2009, 02:00:44 PM by SLIVER »
))--SLIVER-->
Last post May 05, 2006, 10:30:56 AM
by wolffman
Last post Jul 26, 2007, 02:45:37 PM
by dcg9381
Last post Jul 17, 2007, 07:58:51 PM
by MiniSimp
Last post Mar 19, 2008, 09:46:13 PM
by lucky7
Last post Jul 25, 2009, 11:57:27 AM
by zippo
