Author Topic: 1990 toyota 4x4 pickup 22re diferential breathers?  (Read 3985 times)
93tonkatoy
  • Turtle Points: 5
  • Male Posts: 463
  • Member since Jul '07
  • drive it till it breaks! then break out the tools.
Re: 1990 toyota 4x4 pickup 22re diferential breathers?
« on: Jan 02, 2009, 08:58:22 PM »
3/8" air hose works good for the lines, just make sure you route it away from your exhaust. If you still have the LSPV attached, you can zip tie the hose to the arm about mid way up the arm, then run it up into the fender. I would also suggest running the line to the front of the bed, instead of the tail light, because entering and exiting a hole, the front noses down going in and the rear dips down when coming out.
SAVE TELLICO post 491
Last post Dec 22, 2006, 07:43:40 PM
by yota_krawler
Last post Sep 13, 2007, 07:37:21 AM
by bolus131
Last post Apr 27, 2008, 08:51:49 PM
by 51504ROCK
Last post Oct 28, 2008, 01:55:48 PM
by LOL @ IFS
Last post Jul 08, 2010, 02:38:46 AM
by mcphrawg
