You need a R151F bell housing(Turbo trany). The V6 bell Housing will not bolt up to the 22r block but the Turbo bell housing will and also bolt up to a R type Trany. To run the R150F you will need to buy a adapter to run your 1982 gear driven T-case. You will also need to convert your t-case input from 21 to 23 spline.
