Author Topic: vibes with flat belly  (Read 3909 times)
blackdiamond
  • Turtle Points: 1174
  • Male Posts: 5,060
  • Member since Dec '03
  • Crawlin with Marlin
Re: vibes with flat belly
« on: Nov 12, 2008, 12:00:36 PM »
The problem I see is that the rear output on the transer case will be angled slightly up.  This will required additional angles of operation for the u-joint.  It looks like you have an extended cab so you may have a long enough wheel base to make it work.  The more angle in the u-joint the faster they wear.  Also, you won't be able to match the pinion flange angle so you'll need a CV style shaft.
I don't consider a flat belly a DD type of mod, but I'm sure it can be done.  :thumbs:
Last post Jun 28, 2006, 07:00:04 PM
by MR_DIY
Last post Jan 18, 2007, 08:39:13 PM
by Yota4life
Last post Feb 05, 2007, 08:57:46 PM
by Tice
Last post Feb 19, 2009, 11:50:53 AM
by TheCookieMonster
Last post Apr 09, 2021, 04:08:00 PM
by Draggingdiff
