Ok, so today I removed the throttle body,cleaned it,and replaced the gasket. I also checked the ohm readings of the TPS. Looks like I need a new one.
Rechecked the codes and came back with a code 7. So should I replace it with a new one($$$) or look for a used one? It has to pass smog next month (CA SmogCheck II) Test Only
