Author Topic: pinion rotation angle and drive shaft length questions  (Read 2361 times)
Hammerhead
  • Turtle Points: 100
  • Male Posts: 564
  • Member since Nov '04
  • Junkyard Dog
I assemble the axle under the rig with the perches not welded and the U-bolts loose enough to rotate the axle.  With the weight of the vehicle on the springs and the driveshaft in place you can use a jack to push the pinion up until the lower U-joint of the driveshaft is perfectly straight.  I then remove the drive shaft and measure the angle of the pinion flange with a magnetic angle finder.  I then bump the flange back down 2° and that is the angle I want to keep.  I tack my spring perches firmly in place and remove the axle for complete welding.
'82 pickup, +3, locked, doubled
'82 pickup, IFS long travel, V8
'85 4runner, V8 rock crawler
'88 X-cab, V6
Last post Mar 30, 2005, 01:24:46 PM
by donkeykong
Last post Dec 25, 2005, 08:17:07 PM
by 79coyotefrg
Last post Apr 21, 2011, 05:41:42 PM
by blackdiamond
Last post Sep 21, 2014, 02:11:27 PM
by snaggletooth
Last post Dec 28, 2015, 02:36:16 PM
by Tjcarter
