« on: Jan 02, 2008, 02:20:36 PM »
you would be much better off drilling those flange holes out to 10MM and using the larger stronger bolts and they should fit the disc http://www.marlincrawler.com/htm/axles.htm
i might do that for right now i went and got some grade 8 5/16 bolts to bolt it up.i also had to put a washer between the front pad and the bushing that goes in between the pads because it was so tight it would not allow the wheels to spin
![](https://board.marlincrawler.com/Themes/MCI_V3C/images/ip.gif)
Logged
80yota 22r 32/36 weber,header,custom bed,4.88 spooled rear Aussie front ,63" chevies,cage,yada,yada
