How much of a spacer did you need between the stop and the spring bolt plate? (I still need bump stops..)
Has your ford shock towers riped off the frame yet?
If not, they could. Weld in some supports from the top of the frame to the back side of the shock tower.
And the million dollar question.. Does your tire hit the body mount anymore now that you have new shackles and bump stops?
